See pictures below in every step for clearer instructions
Step 1: Go to https://www.phpbb.com/mods/automod/
Step 2: Click Download Latest Automod
Step 3: Go to https://www.phpbb.com/customise/db/mod
Step 4: Scroll down and look for mod you want to be downloaded and click
Step 5: Click download
Step 6: Locate your downloaded automod.zip
Step 7: Extract the automod.zip file
Step 8: Double click the extracted file
Step 9: Double click the folder pointed by the arrow
Step 10: Once you are inside the automod folder. double cick the root folder
Step 11: Copy all the files inside the root folder
Step 12: Go to your localhost phpbb folder and paste all the file
Step 13: Follow the instruction on the picture below. (1) Check the box. (2) Click Yes
Step 14: Go to your localhost phpbb / install
Step 15: Click submit button
Step 16: Click the button "yes"
Step 17: Click "Admin Index"
Step 18: If you still see the Warning message. Go to your localhost phpbb and delete the install folder
Step 19: Go back again to your phpbb admin page and click the Automod
Step 20: Click "upload" and locate the mods you downloaded on Step 5
Step 21: Select the downloaded mod on Step 5 and click open
Step 22: Click the Return to AutoMOD
Step 23: Click "Install"
Step 24: Click "Install"
Step 25: Click the link pointed by the arrow on the picture
Step 26: Click "Submit"
Step 27: Click "Yes"
Step 28: Now the mod is installed successfully, on the right top corner click "Board index"
Step 29: Click forum you want to view
Step 30: Now, just place your pointer on the topic.. The one surrounded by red is my newly installed automod. Other mods are depending on what are their uses.
