Warehouse Management System in Thailand – MDERP Inventory & Stock Management
MDERP Warehouse Management System helps businesses in Thailand manage inventory, stock movements and warehouse operations from a centralized ERP platform. The system supports the complete warehouse process, including goods receiving, storage, internal transfers, stock adjustments, picking, packing, delivery and inventory reporting.
MDERP is designed for trading companies, distributors, manufacturers, multi-branch businesses and international companies operating in Thailand that require better inventory visibility and tighter integration between warehouse operations and other business departments.
Warehouse information can be connected with Sales, Purchasing, Accounting, Manufacturing, POS, E-Commerce and external systems, helping companies reduce duplicate data entry and improve the accuracy of operational information.
For an overview of the complete ERP platform, see MDERP ERP Business Management System .
Why Businesses Need an Integrated Warehouse Management System
Managing inventory with spreadsheets, separate software or manual documents can create several operational problems. Stock quantities may not match the actual inventory, warehouse staff may not know the correct storage location, purchasing teams may reorder products unnecessarily and sales teams may not have reliable information about available stock.
MDERP helps centralize inventory information so warehouse, sales, purchasing, accounting and management teams can work with the same data.
- Monitor current inventory quantities
- Reduce discrepancies between physical stock and system stock
- Manage multiple warehouses and storage locations
- Track receiving, internal transfers and deliveries
- Control product movement using barcode or serial numbers
- Plan replenishment before products run out of stock
- Analyze slow-moving and high-value inventory
- Connect warehouse information with other ERP processes
Multi-Warehouse Inventory Management
MDERP supports businesses that operate more than one warehouse. Companies can separate inventory by warehouse, branch, storage area or operational location and manage stock according to the actual structure of the organization.
Multi-warehouse management is useful for businesses with several distribution points, factories, branches or storage facilities. It provides better visibility of where products are located and helps teams plan stock allocation between locations.
Internal Stock Transfers and Inventory Movements
Products and materials can be transferred between storage locations using internal stock movement processes. The system records the source location, destination location, product and quantity being transferred.
This helps warehouse teams control inventory movements more accurately and provides traceable information for reviewing transfers later.
Physical Inventory and Stock Adjustments
Physical inventory functions allow warehouse staff to compare the quantity recorded in the system with the actual quantity counted in the warehouse. Stock quantities can then be adjusted when differences are found.
Units of Measure (UOM)
Different businesses purchase, store and sell products using different units. MDERP supports multiple units of measure such as pieces, packs, boxes, cartons, kilograms, meters, rolls, days and hours.
This allows product information to match actual business operations and reduces the need to create duplicate products only because they are bought or sold in different units.
Learn more about multiple units of measure in Odoo .
Delivery Methods and Shipping Cost Management
Delivery methods can be configured according to the way each business manages transportation and shipping costs. Companies can define delivery service providers and calculate shipping costs using fixed charges or conditions based on product quantities and weight.
Automated Reordering Rules
Reordering Rules help businesses maintain suitable inventory levels. Minimum and maximum stock quantities can be defined for products so purchasing or replenishment activities can be planned before inventory becomes insufficient.
This helps prevent two common warehouse problems: stockouts, where products are unavailable when customers need them, and overstocking, where too much working capital is tied up in inventory.
Goods Receiving and Delivery Management
Warehouse staff can monitor incoming and outgoing goods from purchasing and sales operations. Products can be received according to the purchase quantity or according to the quantity actually delivered by the supplier.
For customer deliveries, products can be delivered in full or partially depending on actual inventory availability and delivery requirements.
Packing and Warehouse Operations
The packing process can be organized according to actual warehouse operations. Products can be grouped into boxes or packages and warehouse teams can prepare goods according to planned packing and delivery activities.
Clear packing information helps reduce picking and packing mistakes before goods leave the warehouse.
FIFO Inventory Management
FIFO or First In, First Out is an inventory management method where inventory received earlier is normally used or sold before inventory received later.
FIFO can be useful for products that may deteriorate, expire or lose value over time, including food, beverages, pharmaceutical products and other time-sensitive inventory.
The system can also support inventory reporting and costing processes based on FIFO information.
Inventory Costing: Standard, Average and FIFO
Inventory costing is an important part of warehouse and accounting management. MDERP supports different costing approaches according to the configuration and business requirements.
Standard Cost
A predefined standard product cost can be used as a reference for operational and accounting purposes. It can also be compared with actual costs when the business needs to analyze cost differences.
Average Cost
Average costing recalculates product cost based on incoming inventory value and quantity. This method can be useful when products are purchased at different prices over time.
FIFO Cost
FIFO costing tracks inventory value according to the sequence in which products enter inventory. It is suitable for businesses that need to monitor inventory costs by incoming stock layers.
Product Categories and Product Types
Products and services can be grouped into categories that match the business structure. Examples include electrical equipment, office supplies, raw materials, finished goods and services.
Well-organized product categories make searching, inventory reporting and financial configuration easier.
Barcode Inventory Management
Barcode information can be assigned to products to improve identification and warehouse operations. Barcode scanners can be used to search for products and reduce manual data entry.
This improves speed and accuracy when warehouse staff check, count, pick or move products.
MDERP can also be integrated with barcode readers, serial number readers, QR code devices and barcode label printers. See more about ERP barcode and device integration .
Serial Number Tracking
Products can be controlled and tracked using individual serial numbers. Serial number tracking is useful for equipment, electronics, machines and other products that must be identified individually.
Serial numbers can help organizations track product history, warranty information, claims and other product-specific activities.
Delivery Lead Time Planning
Delivery lead time information helps businesses estimate how long it takes to replenish products or materials. Different lead times can be configured according to products and suppliers.
This information can be used together with inventory planning and reordering processes to reduce the risk of raw material or product shortages.
Stock Aging and ABC Inventory Analysis
Effective inventory management is not only about knowing how many items are currently in stock. Businesses also need to understand which products are moving quickly, which products are important to revenue or inventory value and which products have remained in the warehouse for too long.
Stock Aging Analysis
Stock Aging helps analyze how long inventory has remained in stock. It can help identify slow-moving or non-moving products that may require purchasing adjustments, promotions, clearance activities or other management decisions.
For management teams, Stock Aging can also help identify working capital that is tied up in inventory for long periods.
ABC Analysis groups inventory according to importance, value or other business criteria. This helps organizations focus more attention on the products that have the greatest impact on inventory value or business performance.
Using ABC Analysis together with Stock Aging provides a stronger management view because the company can evaluate both the importance of inventory and how long it has remained in stock.
These analyses can help management answer practical questions such as:
- Which products should be reordered?
- Which products should have lower purchasing quantities?
- Which products are slow-moving?
- Which inventory should be promoted or cleared?
- Which product groups represent the highest inventory value?
Receiving and Warehouse Documents
Receipt Slip
Receipt documents help warehouse staff verify incoming goods against purchasing information. Important information can include supplier details, purchase order reference, receiving date, product information and received quantities.
Receiving Labels
Receiving labels can help warehouse staff identify goods and storage locations before products are moved into the warehouse.
Product Labels, Barcode and QR Code
Product labels can display product information as text, barcode or QR code. This helps warehouse teams identify, count, move and prepare products more accurately.
Manufacturing Preparation and BOM Documents
For manufacturing operations, warehouse information can be connected with Bill of Materials (BOM) and production activities. Warehouse staff can prepare raw materials and components according to the quantities required for production.
Businesses that operate factories or production processes can also review MDERP for manufacturing and MRP .
Picking, Packing and Delivery Documents
Prepack and Picking Information
Warehouse staff can use preparation documents to identify products, quantities and storage locations before packing. This helps reduce picking and packing mistakes.
Delivery Slip
Delivery documents provide details about products leaving the warehouse and allow customers or internal staff to verify delivered quantities.
Delivery Note
Delivery Notes provide shipment information that can be reviewed before or during the delivery process.
Packing List
Packing Lists can contain order numbers, package quantities, product details and shipment information. They are useful for logistics teams and businesses that need detailed information about each shipment.
Shipping Labels
Shipping labels help identify sender and recipient information and reduce mistakes during transportation.
Inventory Reports and Stock Checking
Stock Balance
Stock Balance reports help users review inventory quantities and values according to warehouse, product category, product and reporting period.
Physical Stock Count
Inventory count reports can be used during monthly, periodic or annual stock checking processes.
Stock Inventory Adjustments
Adjustment reports provide information about stock increases or decreases and help users review inventory corrections.
Stock Card and FIFO Information
Stock Card information helps businesses review product movements, quantities, document references, lots and inventory costs.
Picking Slip
Picking Slips help warehouse staff prepare the correct products and quantities for internal movement, delivery or other operational processes.
Integration with Sales, Purchasing, Accounting, Manufacturing, POS and External Systems
Sales Integration
Sales teams can use current inventory information when processing customer orders and planning product delivery.
Purchasing Integration
Inventory levels, lead times and reordering information can support purchasing decisions and replenishment planning.
Accounting Integration
Warehouse transactions and inventory values can be connected with accounting processes according to system configuration and business workflow.
Manufacturing Integration
Raw materials and components can be linked with BOM and production processes so inventory movements reflect manufacturing activities.
POS and Sales Channel Integration
Warehouse information can also be connected with POS and other sales channels to help keep inventory information consistent across the organization.
API Integration
For companies that already use other software, MDERP and Odoo can be integrated with external systems according to the available API and business requirements.
Integration can include Marketplace, E-Commerce, logistics systems, payment gateways, banking systems or other ERP applications. Read more about Odoo and ERP API Integration Services .
Who Can Use MDERP Warehouse Management?
MDERP Warehouse Management can be adapted for different types of businesses in Thailand, including:
- Trading companies
- Importers and exporters
- Distributors and wholesalers
- Manufacturing companies
- Factories and production businesses
- Retail and multi-branch businesses
- Spare parts and equipment businesses
- Food and beverage businesses
- Businesses that require barcode or serial number tracking
- Companies operating multiple warehouses or locations
- International and foreign-owned companies operating in Thailand
ERP and Warehouse Management for International Companies in Thailand
International companies operating in Thailand often need more than a standalone inventory application. They may need warehouse operations to work together with sales, purchasing, accounting, manufacturing and existing corporate systems.
MDERP can be used as an ERP platform for companies that require local implementation and customization support in Thailand while still operating with English-speaking management teams, regional offices or international users.
The system can be configured according to warehouse structures, branches, user permissions and actual business workflows. Companies can start with standard ERP functions and develop additional processes when their business requires more specific functionality.
MDSoft provides software development, ERP implementation, customization and system integration services from Thailand. This allows companies to work with a local technical team when analyzing workflows, developing additional functions and integrating MDERP or Odoo with existing systems.
Example of MDERP Implementation in a Real Business
MDERP has been customized and implemented for businesses that require warehouse, purchasing, sales, accounting and integration functions working together.
One implementation included warehouse-related functions together with E-Commerce and LINE integration, demonstrating how ERP can be adapted to match actual operational workflows rather than operating as separate software for each department.
See the MDERP ERP Implementation Case Study .
From Stock Control to Better Business Decisions
A modern warehouse management system should provide more than a current stock quantity. Inventory information should help management answer questions such as:
- Which products are running out of stock?
- Which products are selling quickly?
- Which products have remained in the warehouse for too long?
- When should products be reordered?
- Which items should be reduced or promoted?
- How much working capital is tied up in inventory?
When inventory information is connected with sales, purchasing, accounting and manufacturing, management can make decisions using more complete business information instead of relying on multiple disconnected spreadsheets.
Looking for a Warehouse Management or ERP Solution in Thailand?
If your business operates multiple warehouses, has difficulty controlling inventory, requires barcode or serial number tracking, needs better stock analysis or wants to connect warehouse operations with Sales, Purchasing, Accounting, Manufacturing, POS, E-Commerce or external software, MDERP can be used as a foundation for your ERP project.
The system can start from standard ERP workflows and be customized according to the actual requirements of each organization.
Companies in Thailand with English-speaking teams, international management or regional operations can also discuss their workflow and integration requirements with the MDSoft team.
Contact MDSoft to request an MDERP demonstration, discuss your warehouse requirements or evaluate an ERP implementation project in Thailand.
Frequently Asked Questions
Can MDERP manage multiple warehouses?
Yes. MDERP supports multiple warehouses and inventory locations, allowing businesses to separate and monitor stock according to their operational structure.
Can the system use barcode scanners?
Yes. Barcode information can be assigned to products and the system can work with barcode-related devices according to the required implementation.
Can products be tracked using serial numbers?
Yes. Serial numbers can be used to identify individual products and support tracking, warranty and claim processes.
Can MDERP analyze slow-moving inventory?
Stock Aging analysis can be developed or configured to help businesses identify inventory that has remained in stock for long periods and use the information for purchasing or sales planning.
Can warehouse data connect with manufacturing?
Yes. Inventory and raw material information can be connected with BOM and manufacturing processes so that stock movements correspond with production activities.
Can MDERP connect with existing software?
Yes. Integration can be developed using APIs, web services, file exchange, database synchronization or other suitable methods depending on the external system and project requirements.
Is MDERP suitable for foreign companies in Thailand?
MDERP can be used by international or foreign-owned businesses operating in Thailand that require warehouse, ERP, customization and local system integration support. The final configuration depends on the organization's workflow and implementation requirements.
